Zum Hauptinhalt wechseln
Das Amazon Fire HD 8 (5. Generation) ist ein elegantes, schwarzes Tablet von Amazon. Es kam im September 2015 auf den Markt. Modellnummer SG98EG
Why does my touch screen not work after replacing the Screen?
I have replaced the screen with two new screens and both screen work perfectly except for the touch screen element doesn’t work - is there a connection i am missing or a software reset option that can resolve this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
further to this - i have checked everything inside the unit and it all seems fine so can't see why only the touch screen isn't working. which connection on the device is related to to the touch screen so i can ensure it is seated correctly.
von
just wanted to add a comment in a hope that this would bring it up the response table - i'm still having this issue and the tablet is now siting redundant until i can rectify this issue
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Did you get your replacement screen from iFixit or somewhere else? If you are fine using the tablet without using the touchscreen do the following:
  1. Get a wired mouse and a Micro USB OTG adapter
  2. Charge the device
  3. Plug the OTG adapter into the Micro USB port.
  4. Plug the mouse into the female USB port on the OTG adapter.
  5. You should see a pointer on the screen.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Peter Gustafson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 37
Insgesamt: 915
