Humming Noise from Inverter Board
My iMac make this annoying humming noise, coming from the Inverter Board.
Following this Repair-Guide:
iMac Intel 24" EMC 2111 Inverter Board Replacement
its possible to change the complete Inverter-Board.
My questions are:
Which Part of the Inverter-Board is generating this noise?
Is it possible to replace just this specific part (soldering)?
If not, where can i get a separate replacing Inverter-Board?
iMac Intel 24" EMC 2111 video flickering issues question
Ist dies eine gute Frage?
8 Kommentare
What are the last 3 characters of your serial number so can verify the machine and better help you? Is the screen flickering and humming or is the backlight constant and humming?
von ABCellars
Serial Nr.: W865200XVGP
No screen flickering at all. Just this annoying humming noise.
von cyrillpfister
Apple iMac "Core 2 Duo" 2.16 or 2.33 24-Inch Specs
Identifiers: Late 2006 - 24" - MA456LL - iMac6,1 - A1200 - 2111
von mayer
I am having a hard time finding an inverter without the LCD.
von ABCellars
More than likely the issue is form one of the transformers on the inverter board. they are most definitely replaceable however I would need to see the board to tell if a replacement transformer can be found.
I am also having no luck whatsoever finding a replacement inverter.
von Max
3 weitere Kommentare anzeigen
