Zum Hauptinhalt wechseln
Diese Seite beinhaltet Reparaturanleitungen und technische Rezensionen des Huawei Mate 10.
Battery compatible with Mate 10 Lite?
Does anyone know if the battery ifixit sells for the mate 10 is also compatible with the mate 10 lite?
https://store.ifixit.de/products/huawei-...
There’s no battery explicitly for the lite version. It’s so %#*@ hard to find the actual battery specifications of the phone, I just found the capacity which is higher in the above battery.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @kryptojude ,
They are different batteries.
The model number shown for the Ifixit battery that you linked is HB436486ECW (printed on battery)
The model number of the battery in a Huawei Mate 10 Lite as seen in this video is HB356687ECW - see image taken from video.
They have different dimensions and capacities and I don’t know if they have the same pin out connections in the battery cable.
Mate 10 battery dimensions = 4.3mm x 64mm x 86mm, rated capacity 3900mA
Mate 10 Lite battery dimensions = 3.5mm x 66mm x 87mm, rated capacity 3240mA (actual capacity 3340mA)
Here are the full specifications for the phone
(click on image to enlarge for better viewing)
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Thanks a lot!
von
Antwort hinzufügen
Kryptojude wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 588
