Zum Hauptinhalt wechseln
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Why want my 04 ford escape start. Battery is good starter relay is goo
Battery is good my starter relay is good. I replaced my whole starter 2 times. There is a sound comeing from the fuse box under hood. And a light noise from around the starter when trying to crank. All my lights raideo windows etc work. But it dont crank.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Do you have access to a volt meter? When you try to turn it over do you hear any noice? Also if you try to turn it over with the lights on does it dim the lights? Is the noice you hear near the fuse box a click or a buzz sound?
Update (07/02/2021)
Try turning it over with the lights on does it dim the lights? If so check battery. If not then it is likely the starter.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
It is a click like noise and around the starter is another noise.
von
It is a click noise. ………
von
Antwort hinzufügen
Dee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 195
