Zum Hauptinhalt wechseln
This guide is designed to help HP ProBook 650 G2 owners get the most out of their device by providing essential information for maintenance, upgrades, and troubleshooting. Whether you're looking to replace components, troubleshoot performance issues, or simply understand your laptop's specifications better, this guide offers detailed instructions and helpful resources. It highlights the key features of the ProBook 650 G2, including its upgradeable memory and storage, and provides step-by-step support for common repairs. By using this guide, owners can improve the longevity of their device and ensure it continues to perform reliably in a business environment.
Replace PowerJack for AC/DC Adapter
How difficult is it to repair power jack on Probook HP 650 g2 laptop
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @bully357 ,
You would need soldering tools and skills to replace the power jack (supplier example only) in your model laptop.
It also involves dis-assembling the laptop to remove the systemboard so this can be done.
Here’s a video that shows what’s involved. The actual DC power socket replacement is seen from ~26:30 minutes onwards into the video.
Here’s the maintenance and service guide for the laptop, which may also help. Go to p.60 to view the necessary pre-requisite steps and then the procedure to remove the systemboard
War diese Antwort hilfreich?
Bewertung 1
Hello Jason Bolstad! Power jack replacements on these types of laptops can range from very easy to do to very difficult. However, on your particular laptop, it would seem as if the charging port is directly soldered onto the motherboard instead of connected to it through a cable. The latter would be much easier to replace as it would only require you to open up the computer, unplug the faulty charging port, and replace it with a new one. However, as all of the ports of your laptop are on one side of it, this indicates that the charging port is directly soldered to the motherboard. I have confirmed this through some research on your laptop’s motherboard. This would mean to replace the charging port, you would need to open up the computer, take out the motherboard, desolder the broken charging port, and solder on a new one. This can be very difficult to do for a person who has never heard of or touched a soldering iron before, but if you would like to try it, you can consult some people on iFixit that have experience with this type of repair. One thing that you could do to try to test if the charging port is indeed the problem is to buy a replacement power cord for your laptop as that could be the issue instead. I hope this has helped to fix any problems that you have had and resolved any issues with your device.
Bewertung 0
Antwort hinzufügen
Jason Bolstad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 919
