Zum Hauptinhalt wechseln
Repair and assembly guides for the Honda General Purpose Engine model GXV160UH2.
1 Fragen Alle anzeigen
Need general tips and advice for fixing up a broken lawnmower.
Hello, I need some general tips and advice for fixing up an old lawnmower. I haven't put any fuel or oil in yet and tried to fire it up, should that be my first step? If so what next? Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It depends. I would put some oil in it and it a couple of times by pulling the starter just to see if it is seized up or not. Give it a good cleaning. And check the blade to make sure it is on tight. Smell the gas to see if any left and if it smells bad. If it does pull tank and carb and clean. Check spark plug and make sure it looks OK. Then try to start it.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks man. I'll give that a try and see what happens and possibly ask another question or two ?
von
Ask all you want.
von
Antwort hinzufügen
Heinz Beanz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 83
