GE Refrigerator Evaporator Frozen - Temps High (pics)
GE FRIDGE: GSH25JGBBBB
https://www.geapplianceparts.com/store/p...
Came back from a 10 day vacation and noticed the Freezer temp was in the 20’s/fridge 50’s (should be 0F and 37F). Before I left for vacation I turned off the water to the house and put the AC on 75, could doing either of these caused this or just a coincidence? I ask because I’m going out of town again in a two weeks.
I’m guessing this is the issue? The evaporator is totally frozen solid.
Any help on what I should try first to fix this? I read it could be the defrost heater, defrost thermostat, or defrost control. Should I buy all 3 or rule them out 1 by 1? Or just hire someone? Honestly don’t want to deal with this if it will only cost a couple hundred bucks to fix.
Update (07/17/2021)
Here’s my Defrost Heater Assembly :
Ist dies eine gute Frage?
3 Kommentare
Oh yes... that appears to be quite toast. That combined with an open reading across... replace that and you should be golden. Please let me know how it works after replacing it.
von brandon k
Sure thing, I went ahead and got a new Temperature Sensor WR55X10025 as well since it was only $15, both should arrive tomorrow so here's hoping. For anyone that comes across this I found the cheapest prices at Sears PartsDirect, the Defrost Heater Assembly was $20 cheaper than any other website.
von Nate
I installed the Defrost Heater Assembly on Thursday and everything seems to be working fine. The freezer and fridge will jump up or down by 1 degree sometimes but they mainly stick around the temps I set, maybe the change in temps is normal if it's going through a cycle. I'm gonna assume (and pray lol) this issue is fixed, thanks for all the comments!
von Nate
