Zum Hauptinhalt wechseln
Reparaturen für eine Vielzahl von Schallerzeugern, einschließlich Lautsprechern und Lautsprecherkomponenten.
2704 Fragen Alle anzeigen
How to open up the Anker A7908 Bluetooth speaker?
My Anker A7908 is having some issues and I wanna take a look inside, but I'm not entirely sure where to start with taking this thing apart. I don't want to just start prying an pulling in random places. Does anybody have any suggestions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Manufacturers love to hide screws under rubber feet. Try prying that rubber base off.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
You were right. Thank you very much!
von
Hi! I got the screws out but I'm not seeing a good place to be able to pry the bottom off. What did you do once you got the screws out?
von
@printedwaffles, after that there is only one tiny part that may still stick a bit.
Visible on the right of the picture (marked with silver marker).
Bewertung 2
2 Kommentare:
Thank you, I'll give it a try soon. Did you use a plastic/rubber/metal pry piece to get that to pop out?
I'm pulling it apart because the battery is toast. Do you happen to know the right type of replacement battery for this thing?
Thank you! Very much appreciated!
von
Important in my effort to get the bottom off - there are FIVE screws in the bottom!
I was trying to pry off the bottom after having removed screws on four sides and it wouldn't budge at all. Only by luck did I realize a fifth screw was hidden under the glue strip.
Bewertung 0
1 Kommentar:
Now that I have it apart I was able to check the battery. It's at roughly 4 Volt, so fully charged, but it still won't turn on. Any tips? The only light I get is the red light when connected to a charger. the on-off button or the others aren't doing anything.
von
Antwort hinzufügen
Lars Lensink wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 48
Insgesamt: 1,507
