Zum Hauptinhalt wechseln
Die Slim-Edition der klassischen Xbox 360 mit 250-GB-Festplatte und integriertem WLAN. Die Reparatur erfordert vorsichtiges Hebeln und spezielles Werkzeug.
Why did my Xbox 360 S turn off by itself?
Hello, my Xbox 360 Slim just turned off randomly. It didn't respond to the power button getting pressed. So I unplugged the power supply from the Xbox, after it booted up just fine but after 30 seconds it did the same thing again. (I heard a beep before it turned off.)
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Sounds like it may be overheating. Have you cleaned the interior any? There may be a build up of dust causing it to overheat and shut off because it can’t cool the Xbox properly. Try opening it and seeing how much dust is in it, and if there is a lot take a brush and clean it out, and see if the issue persists. Hope this helps!
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
It's not overheating, I had it on for 3 minutes then while it was loading it beeped and turned off.
von
Antwort hinzufügen
Kur Yente wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 407
