Zum Hauptinhalt wechseln
Repair guides and support for a wide range of Vespa scooters.
My bike built june99,98/99model?
I have vespa et50 two stroke 1999, I believe it is 98/99 model therefore old engine and need parts but being in mid of change have to be sure it’s older or newer engine, can you resolve pls as no one seems to know and belt and rollers replacement, belt for newer model is 11mm longer and would not fit if mine older make
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
precious lightwood-carroll we will need your Vespa's serial number. Either the one from the frame or from the engine.
von
Einen Kommentar hinzufügen
2 Antworten
Hello precious,
ET2 50 made between 1996-2001 has the the following frame prefix: ZAPC160
Whereas the ET2 50 made between 2001-2005 has the following prefix: ZAPC381
https://de.m.wikipedia.org/wiki/Vespa_ET
https://www.motorscooterguide.net/vespa-...
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Christophe VAULLEGEARD double check something for me please. My data shows that the ZAPC381 is actually a LX50 not a ET50 Just making sure that I have the correct info. Thanks.
von
precious lightwood-carroll  it is the 10th digit on your Vespa’s serial number that is the model year. So your VIN (being a 1999) would start with something like ZAPC1600 (as Christophe VAULLEGEARD  pointed out) which does NOT indicate the year.
ZA= Made in Italy
P= Piaggio/Vespa
C161M= Engine code
next should be model number and finally the 10th digit is the model year. So yours may show a number 9 Of course we would need to have your Vespa’s number to verify and assist you further.
Bewertung 0
3 Kommentare:
Hi,
Once you get the year sorted here are a couple of links that may help as they have the parts diagrams with all the part numbers which should make it easier to find them.
ET2 50 1998
ET2 50 1999
von
@precious lightwood-carroll any chance you missed a letter number? I would expect the 4th letter to be a “C” for the engine code. That would mean your scooter is a ‘99 model. If the number you gave us is right then it is actually a 2003 model. So, double check to verify
von
Antwort hinzufügen
precious lightwood-carroll wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 509
