Zum Hauptinhalt wechseln
Veröffentlicht am 26. Oktober 2018. Modelle A1984, A2105, A2106, A2108. Erhältlich als GSM oder CDMA / eSIM, Nano-SIM oder Dual-SIM / 64, 128 oder 256 GB / Schwarz, Weiß, Blau, Gelb, Koralle oder Rot. (Ausgesprochen "iPhone 10 R.")
468 Fragen Alle anzeigen
iPhone XR doesn't turn on or show any current?
Hello, I have an iPhone XR logic board which I replaced the charging IC on, (it didn’t boot before replacement) and it still won’t boot. When I press the power button there is no change in the current and it stays at zero. The logic board is not getting hot. Any ideas or solutions? Thank you for your help!
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
We will need a lot more info for us to help you.
What charging IC did you replace? Any amp draw when you prompt to boot with usb cable?
von
I replaced charging Tigris IC (U3300). I replaced this chip because it was getting really hot, and after the replacement it was no longer getting hot.
I installed the motherboard into a housing and connected a DC power supply to it, and it didn’t draw any amps. I pressed the power button however it still stayed at 0 amps.
von
@Colby Morris It could be a faulty coil. They often fail on the XR. I would replace L3301, 2, 3, 4. I usually replace these when replacing Tigris.
von
Einen Kommentar hinzufügen
1 Antwort
Hi! This is a problem that is caused by updating the software on iPhone XRs and sadly, it is common and sometimes can’t be fixed. You can try your luck doing factory resets through a Mac, but you may need a new phone. This happened to my mom and her phone is completely dead trying to update to iOS 14.3.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I understand this could be the case however I bought this phone off of eBay and have no clue on what iOS version it could be, I never connected it to iTunes and even if I did I don’t think it would detect it since I can’t turn it on. Thank you for your answer though!
von
You’re welcome!
von
Antwort hinzufügen
Colby Morris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 242
