Zum Hauptinhalt wechseln
Repair guides and support for your Philips TV.
242 Fragen Alle anzeigen
No HDMI input detected on Philips 42pfl6007h/12 TV after thunderstorm
Hi, my tv was struck by lightning and has suffered some damage, It has lost backlight power which I believe is due to a faulty PSU (I’ll be replacing it in the future) but I’ve also lost all video output on the HDMI ports. I’ve checked the inside of the tv and there appears to be no damage and so I followed the traces from the HDMI ports to a chip which I have circled in the below image
the chips has this number on it - SIL 9387. Looking up the datasheet for the chip I found this:
from what I understand, this means that that pin on the chip should contain 3.3v however it does not and only contains around 0.1v when tv is on, does this mean that the chip is bad and that I’ve found the problem? Extra note: The chip gets noticeably hotter than the other chips however I’m not sure if this is normal (Cpu gets quite hot to the point where I can’t touch it’s heatsink for more than a few seconds but I assume this is normal as it is working fine) I’m not very good at diagnosing electronics so any help would be greatly appreciated.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Since a TV takes HDMI inputs, not outputing them to display on another device, are you seeing a message of no HDMI Signal on the screen?
It could be the device that is sending the signal, or the cable, but could be the port. Have you tested the other device that is sending the HDMI signal to make sure it is working correctly? How about the cable?
Since your research shows the Vcc should be at 3.3V, and is showing 0.1V, and not 0, it could be the chip is good. Processor chips to run hot. A 486 CPU when running at full speed is too hot to touch.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Nvidia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 359
