Zum Hauptinhalt wechseln
1,8 GHz Dual-Core Intel Core i5 (Turbo Boost bis 2,8 GHz) mit 3 MB geteiltem L3-Cache
371 Fragen Alle anzeigen
MacBook Air display problem?
Hello.
Macbook is having weird display error.
The error comes up randomly and restart the PC itself.
Screen is shaking, 5 cm bars will come to the display.
Someone have experienced similar issue? Gpu ? Display itself or bad ram?
Update (08/02/2021)
Picture once more.
Update (08/03/2021)
Did the RAM reflow and now the macbook boots up fine.
Is there any way to test is it coming back or i just need to wait?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
What does an external display show via the HDMI or mDP/TB port
von
And now when triwd to power on . It continues 3 beeps - that means something is wrong with RAM?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The integrated graphics engine within the CPU chip uses part of the systems RAM for video RAM so what you are seeing is the corruption of the video image within the video RAM space.
Basically your RAM has a problem so you’ll need to find someone with the needed tools and parts to replace the RAM chips or I would get a replacement logic board as being the quicker path MacBook Air 13" (Mid 2012) 2.0 GHz Logic Board and here’s the guide MacBook Air 13" Mitte 2012 Logic Board austauschen
MacBook Air 13" (Mid 2012) 2.0 GHz Logic Board Bild
Produkt
$224.99
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you for the answer.
Is it possible to reball the RAM? Or this is not permanent fix?
von
@kapuzta - Re-balling is the action of desoldering the chip cleaning off the old solder, then re-tinning the chip and the pads and re-soldering the chip back down.
The assumption is the solder joint failed. It's a lot of work doing each chip one by one. You really don't need to go to this length. A hot air station and a good flux is what I would go with, You still need good micro soldering skills as you can easily short out a connection. This is not a typical DIY project.
But keep in mind you are assuming a solder joint, what if the RAM chip its self failed? Now you need a replacement and you often need to replace all of them as the speed and the CAS/RAS of what Apple used for chips needs to be matched. You can't replace one with a different value.
von
Thank you Dan.
I have done the reflow and the macbook works well.
Hopefully it stays like that :).
von
Hilfreichste Antwort
@kapuzta Yes, 3 beeps means bad RAM.
Bewertung 2
Antwort hinzufügen
Kaspar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 166
