Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
342 Fragen Alle anzeigen
Screen has weird rgb pixels everywhere boots into white screen after
This started happening yesterday so I turned it off and left it overnight it was working for a little bit but it started happening again with these weird pixels and booting into a white screen
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like the GPU board is failing! In its day the AMD GPU was able support the apps people where using. Sadly the Apps matured very fast and eclipsed what this GPU could support. It just doesn’t have needed compute power without overheating when pushed hard.
You might be able to get a little more life out of your system by cleaning the system of the dust buildup as well as apply a fresh coat of thermal paste on the CPU & GPU chips. In addition I would install a good thermal monitoring app like TG Pro which will allow you to see what’s happening and allow you to push the fans harder when you are pressing the GPU a bit too hard.
Here’s the guide you’ll need to follow iMac Intel 21,5" EMC 2389 GPU Karte austauschen
Its a big job! You may want to find someone locally who’s done a few iMac’s already
You’ll need thermal paste and thermal pad material to make new pads for the VRAM chips before you start.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you !!
von
Antwort hinzufügen
A R wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 83
