Zum Hauptinhalt wechseln
Modell A1297 Unibody; Anfang 2009, Mitte 2009, Mitte 2010, Anfang 2011 & Ende 2011
544 Fragen Alle anzeigen
GAH! I stripped the head of one of the logic board screws!
I'm removing the logic board of my early '09 MBP 17' so I can remove the heatsink to replace the thermal grease with some better-applied high-quality stuff to see if I can improve heat transfer from the CPU etc. to the heatsink. This should improve thermals by a noticable amount from what I've read. I would be finding out for myself just how much this helps if I could just get this screw out! I was careful about it and everything; correct sized screw driver (from iFixit), enough downward pressure but not alot of turning torque. I got most of the other screws out without a hitch, and this one just started giving out without budging.
So! I need advice on removing said screw.
Edit: It seems I already have someone who can help me procure a replacement screw.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
The screw was a 3 mm right? Do you still need it?
von
Yes, I emailed you from my gmail account with the same screenname.
von
It went out today.
von
Thank you so much!
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Here's a thread from ehmac.ca my favorite canadian Mac discussion forum about a similar problem:
http://www.ehmac.ca/mac-iPod-help-troubl...
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
That's got some very helpful ideas! Might just try the glue one.
von
Hilfreichste Antwort
Tell me which screw it is and I probably have it.
Bewertung 4
4 Kommentare:
It's one of the 3.2mm Phillips screws that fasten the logic board to the chassis (all of these are the same length). More specifically, it was the one in the corner by the Superdrive and the battery.
von
I have to go to bed soon and I will need to find my bolly and dig in my screw bottles but I believe I have it in hand right now, just need to measure. I should be able to confirm by 1400 CST tomorrow. Need your email now and then I will delete the post.
von
Check the tear down to see if it isn't a 3mm not a 3.2mm
von
I was asked about the boley. It's called a bolly gauge and it primarily used in dentistry. Measures millimeters with pinchers.
von
If you have a dremel tool with the thin cutting disc, you can sometimes cut a groove into the screw head that will then allow you turn it with a regular flathhead screwdriver. Just be careful not to cut too deep, or you run the risk of slicing half the head off.
Bewertung 0
1 Kommentar:
I would be very weary about taking a dremel to it, as the screw head is only roughly as thick as a fingernail, and as can be deduced from the problem, very very soft. A dremel would have no problem going right through it and straight into the logic board.
von
Antwort hinzufügen
waffle911 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 5,729
