Zum Hauptinhalt wechseln
Das Moto G Power 2021 von Motorola ist ein Gerät mit einem 6,6" Max Vision HD+ (IPS) Display, einem 48-Megapixel-Dreifachkamerasystem und erweiterbarem microSD-Speicher.
Why is my screen color looking like a negative picture I had a normal
Please help me get my phone screen and picture back to normal.
Ist dies eine gute Frage?
Bewertung 9
Einen Kommentar hinzufügen
8 Antworten
Hilfreichste Antwort
Try Settings>Accessibility>Set Color inversion to off.
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
, well I tried that it didn't help my phone still looks like it has a negative I don't know how to fix it
von
Hi @Lynda Garcia
If you have a Moto G power (2021), try starting the phone in safe mode and check if that resolves the problem.
If so follow the instructions in the link to find the cause.
von
Try turning negative color mode on then off.
Bewertung 3
1 Kommentar:
i agree that would work!
von
I went into accessibility and kept on inversion color it might be another name on your cell phone but it has to do with color and then you can tap a couple of different buttons that you see and try them and it brings the screen back to normal my cell phone was like that for 2 days
Bewertung 2
Check the display screen connectors. Make sure they're connected completely and correctly. I would remove them, make sure there is no dust or lint and reconnect.
Bewertung 0
3 Kommentare:
my phone galaxies12 does not have any colors in his pictures
von
that did not help
von
If the broken display is still available, disconnect the new one, reconnect the old one. If the display shows as it should, the new display is faulty. Send it back with an explanation and get a new one. If the display does NOT show as it should, it's possible something was damaged on the board during the repair. You can use a camera's zoom to check.
von
Its not a problem its a feature of your smartphone it is made for those people who like to read books in their smartphone.
To fix this issue you just have to disable it from the settings and after it you are done.
https://okadtech.com/moto-g-screen-color...
This article will help you to disable this feature.
Bewertung 0
I am not wanting to. Disable my phone then who will fix that?
Bewertung 0
4 Kommentare:
By doing this you WILL NOT disable your phone. You will just shut off the "invert colors" mode.
von
My phone looks like a negative how can I fix this
von
@shiela markley What have you tried doing to fix it? Did you try the suggestions in this thread? Are you also talking about a Motorola's Moto G Power 2021?
von
What happens when that don't work it did in safe mode in galaxy a03
von
My screen is in negative mode, n
How do I get it back to normal
Bewertung 0
2 Kommentare:
Hi @ro3471,
von
A Samsung a14
von
How do I get my phone color back to normal
Bewertung 0
Antwort hinzufügen
Shane Schlamann wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 10,893
