Zum Hauptinhalt wechseln
Das Flaggschiff-Smartphone von Huawei erschien im April 2019. Es hat ein 6,47 Zoll FHD+OLED Display, eine Hauptkamera mit 40 MP und 8 MP Telekamera und einen neuen Ohrlautsprecher. Der Fingerabdrucksensor befindet sich im Display,
43 Fragen Alle anzeigen
No audio from bottom microphone
Hi all, I realised my P30 Pro’s bottom microphone stopped working. All apps that use this (Shazam, Google) pick up no sound from it. If I’m on a call, i have to wait between 5-10 seconds (which I think is when the top mic kicks in), then person can hear me. I have factory reset, cleared all caches but no luck so going to attempt changing the microphone/ SIM board. Has anyone done this before with success? On eb@y there are some boards that have this little silver IC in the middle of the board, and some don’t (this is on the opposites side of the SIM slot). Does anyone know what that is?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I changed bottom board with microphone and still doesnt work
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Yes same problem I had. Changing the sim/mic board will fix problem.
War diese Antwort hilfreich?
Bewertung 2
You're on the right track.
This is exactly what the p30 pro does when the bottom mic stops working.
The mic is soldered on a small pcb that has the simtray on it.
Do inspect your part before installing it because I’ve seen alot of them being very badly refurbished for resale where the IC and stucked there with glue instead of being soldered to the board. It might be hard to see without a microscope, but I just want to let you know that that is a common practice with the P30 pro sim/mic board for some reason.
I hope this helps.
Bewertung 1
2 Kommentare:
Thank you for your response. There are 2 ICs on that board, one close to the mic port and one in the centre of the board. Do you know which one it is?
von
I'm sorry, but I'm not sure I understand your question.
Just look at your board to see if the IC location matches what you are buying.
I think there maybe 2 version or so. That is because some countries uses dual sim, and some only uses single sim.
von
Bewertung 1
Antwort hinzufügen
theun4given1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 75
Insgesamt: 4,155
