Eine preisgünstigere Version der Nintendo Switch Spielkonsole als rein tragbare Konsole, mit eingebauten Joy-Con Controllern und etwas kleinerem Bildschirm. Erschienen am 20. September 2019.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare:
Can you explain a bit more to what you are reffering to?
Oh like the head is stripped? If you were able to get a little bit of it out then a pair of fine point pliers could grip on it enough to get a couple.of turns out.
Also sometime placing an elastic in the head of the screw before putting your screwdriver can help get some grip.
If you have bigger bits you could try to see if one fits with the new shape made by stripping it.
von Innovatrix Repairs
@innovatrix I was opening up my switch but I can’t get a screw out it look like it is damaged and I have no idea how to remove it
von Arjun Manikandan
I hope this helps
