My cruise control only works when it wants
My 2011 Silverado 1500. The cruise control only works when it wants to. I press the cruise button and nothing happens; after a while or another day it works for a while
Ist dies eine gute Frage?
From what I'm finding, a common fix that has worked for many and is cheap has been to replace the brake lamp switch. Its like $20. If that doesn't do it it might be an issue with the switch/buttons itself and you might have to replace that. Next time it doesn't work try tapping the brakes a bit and trying again. If it starts working then replace the brake switch.
War diese Antwort hilfreich?
The cruise module is down behind the brake pedal U can replace it Or if it doesn’t work when u press it Just give it a little kick and it will work.
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 823
