Zum Hauptinhalt wechseln
This Power Mac G4 has Mirrored Drive Doors.
80 Fragen Alle anzeigen
G4 CPU replacement "How To"?
I want to upgrade my dual 1.25GHz G4 MDD PowerMac to use the dual 1.42GHz G4 FireWire 800 CPU card. It is my understanding that the bus speed for both of these models is the same and the swap should be an easy remove and replace procedure, but I can't find any information that describes exactly what I am trying to do, or how to do it.
I also would like to possibly over-clock the dual 1.42GHz G4's up to 1.5GHz, or 1.67GHz, if they do not produce too much extra heat at those speeds, so information on where to find directions on how to over-clock the dual 1.42GHz G4's to 1.5GHz, or 1.67GHz would also be welcome, in addition to opinions on the reliability and stability of this modification.
Thanks,
David
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Here's information on 3 different CPU upgrades for the MDD: http://lowendmac.com/musings/07/0522.htm...
Here's the PDF with pictorials on CPU installation: http://www.sonnettech.com/support/downlo...
Before spending bucks on this upgrade make sure you're running programs that will utilize the dual processors.
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
David Morris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,763
