Zum Hauptinhalt wechseln
Modell A1419 / EMC 2806 / Ende 2014 oder Mitte 2015. 3.3 oder 3.5 GHz Core i5 oder 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 Ende 2015 / 3.3 oder 3.5 GHz Core i5 oder 4.0 GHz Core i7 (iMac17,1) alle mit Retina 5K Displays
573 Fragen Alle anzeigen
Safari crashes on opening in Safe Mode with Migrated User but not new
This one is a head scratcher. Installed 2TB 2.5” SSD, Installed Big Sur. Created New Test User. Safari runs fine. Migrated a user in and Safari crashes. The problem that has me scratching my head is that it crashes in Safe Mode. If I switch to the new user, i have no issues. Any ideas on where to look?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Did you check it for malware/spyware/viruses to make sure there’s nothing lurking.
If not, then you have something cached in the Safari settings. Try launching Safari while holding the Option and Command keys.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Installed new Mcafee app and scanned, it found nothing. Tried the Option & Command keys and starting Safari with no results. Did this twice. Strange machine, it was almost brought down to running at 1/5 normal speed by Spotify V 1.1.34.694, when I trashed that it came back to running at normal speed. It was not in the Startup items but would just come on sometimes. I replaced it with the newest version of 1.167.586 and had no problems.
von
That only leaves wiping the drive and re-install a clean OS again.
This time only migrate the user account info, not the Apps or users data!
Then see if Safari is working at that point. If it is they restore the apps and check Safari again still working? Then manually copy over the users data. That should do it.
von
Antwort hinzufügen
mayer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 52
