Zum Hauptinhalt wechseln
Die Sony PS5 wurde im November 2020 veröffentlicht und hat viel bessere Graphikleistungen und einen innovativen neuen DualSense Controller. Das neue Farbschema hat was von Weltraum und ist eine bemerkenswerte Abkehr von den alten Designs der PlayStation.
PS5 SSD installation - replacement screw and spacer
I tried to install a new WD SN850 SSD in my PS5 last night. However when I went to remove the screw and spacer in the bay, the screw was stuck, and I just can’t remove it at all. I’m looking for a replacement screw and spacer to fit the SSD. Does anyone have any recommendations from Amazon UK or any other retailer? I’ve contacted Sony, but they haven’t got back to me at all, which isn’t a good sign. Many thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
9 Kommentare
I got the same problem too. Currently trying to find similar screw and spacer in SEA market but can't find nothing
von
@Akifan Jannata I still haven't had a response from Sony Customer Support. I'd happily buy the screw and spacer if I knew what I was looking for! So frustrating!
von
Hi i have the same probleme if one of you find the good dimension for the screw can you tell me
von
To replace the screw that holds down the M.2 access cover, use a M3 × 16 screw.
To replace the screw that holds down the M.2 SSD drive, use a P3 × 10 screw.
To replace the spacer that supports the M.2 SSD drive, use a spacer with the dimensions φ5.5 x 3.95 mm.
von
Where do they sell the spacers? I can't find it with an internet search.
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
I have found a screw that has done the job for me. I got the M3-0.5 x 10mm flat head phillips screw, which fits perfectly. I didn't need a spacer either. The screw did the job on it's own. Hope that helps
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
From which UK shop?
von
I ordered a new screw and spacer on Amazon. So am I good to just leave the stuck/stripped one in it’s original 110 slot?
von
This is the screw I replaced the original stock screw inside the ssd bay that holds down the ssd.
Update (06/05/2022)
This is the original screw that came with the ps5 that I damaged.
Bewertung 0
2 Kommentare:
4-40 x 1/2 in. machine philips pan head screw fits inside the original ps5 spacer
von
Here are images to see that the 4-40x1/2in. screw fits inside the ps5 ssd bay.
Bewertung 0
3 Kommentare:
Bro what is the size of screw you displayed in 2nd image
von
Is the screw properly fixed with ssd?? And what's the size of it?? Plz inform me Asap.
von
Sorry for the late reply. The screw size is 4-40x1/2in screws.
von
https://amzn.eu/d/iJrAFeV
Bewertung 0
I found this on Amazon UK, "Amazon's Choice" for ps5 ssd screw and spacer
DevineCustomz® Compatible For PS5 Mounting Solid State Disk SSD Screw Replacement Nut Console Motherboard Metal Screws
Bewertung 0
Antwort hinzufügen
Kevin McCubbin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 30
Letzte 30 Tage: 127
Insgesamt: 39,167
