Zum Hauptinhalt wechseln
Reparaturinformationen und Unterstützung für handgeführte Rasenmäher der Toro Company.
Self Propelled Lawn Mower Not Moving Forward on Grass
I have a Briggs & Stratton High Wheel Variable Speed Gas Walk Behind Self Propelled Lawn Mower with Bagger ( model#21378) that was purchased 8 months ago. I was cutting the grass a couple weeks ago, and the mower stop moving forward half way through cutting. My neighbor has a passion fruit tree on their yard; the mower got stuck on a branch. I pulled it back a couple inches and move around the branch. That's when I realized the self propelled no longer working when engaged on the grass. I pushed the mower on the driveway and engaged the self propelled again, and it worked there. It stopped working on the grass but worked fine on concrete.
I did a little bit of troubleshooting. I removed the wheels to check for debris; they were cleaned. The driving belt was on the pulley. The belt did not look damage. When I engaged the self propelled, I noticed the belt tighten up a little. However, the cable felt a little loose. Do I need to replace the cable, or could it be something simpler?
The mower is still under the company's warranty, but the approved dealers told me they are 3 months behind and would not be able to get to it before that. I am hopping to find a solution online and not having to take it to the dealer.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There is an adjustment for the drive cable described in the owner’s manual. You may need to take up a little on it. If you don’t have the manual, it is available online by searching “Toro model #21378 owner manual”.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@mike3 that was it. I adjusted the cable, and it's been working. Thank you.
von
Antwort hinzufügen
Ferice wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 38
Insgesamt: 2,892
