Turn signals not working
My turn signals aren’t working on my 2001 Cherokee. I replaced 2 bulbs and checked all the rest. When I force the right signal it blinks once then nothing
Ist dies eine gute Frage?
@lbrannock11 check the blinker relay because that could be what is causing this. Not a terribly complicated job. This video makes a pretty good job of showing you how to replace it.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 381
2 Kommentare
Changing the relay lit up the signals so I can manually make them work but it stopped my hazards from working. This is as far as I can go as I can’t take off the steering wheel
von Lisa Brannock
@lbrannock11 you made sure that you have the proper bulbs in your lights? Some of the multi filament lights can cause this if they are the wrong type.
von oldturkey03
