Sadly your systems ports don’t offer USB-C abilities natively!
With that said many USB-C devices do offer older USB connectivity. As an example the Samsung T5 Ext SSD drive Note the Interface line: USB 3.1 Gen 2 (10Gbps), Backwards Compatible
Basically, the USB-C standard incorporates some of the signal lines for compatibility to the older USB 2.x/3.1 standards as they knew people needed this to move forward.
To be clear you won’t get the higher throughput in older USB-2.x or USB-3.0 systems but you can start the process of switching over to newer devices like drives.
Now let’s look at it from the other direction: Your older USB-A connecter devices will now need an adapter to connect to USB-C systems. So consider what you have now that you’ll carry forward and the cost to replace them. As well as the waste of a still very useful device going into land fills!
Many people are still very glued to the older USB-A based devices and not likely to switch over anytime soon.
We’ve seen the same effect within Ethernet networking! As the data rate increased the need to switch out your wiring became a hardship for companies and people homes with in-wall wiring. Cat-5e wiring is what you’ll find as much as the industry tries higher Cat-6 or 7 wiring and connectors are not being pulled. People are just jumping to glass fiber if they can afford it! As its too is costly to rewire and besides how many people are even pushing 1 Gbps!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
