Zum Hauptinhalt wechseln
Cheap & Cheap Asus E410MA-EK945TS 14 inch laptop for everyday use, introduced May 14, 2020. CPU: Intel(R) Celeron(R) N4020 1.10GHz | Maximum: 2.8GHz GPU: Intel UHD Graphics 600 RAM: 4GB Storage: 64GB SSD
Laptop USB Port only works at a certain angle
I’ve got a laptop with 2 USB Ports, but one only works at a certain angle. Works fine when pressure is constantly applied, no rotation. Works when tilted down (from upper view). Works when USB is between plugged in & unplugged. Sometimes my mouse lights up, but it doesn’t work.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I have one that is intermittent also. I think it is the contacts inside the socket. They are a spring hump design. If you are careful, you may be able to lift them using a fine tweezer. They won’t need to come up much. Get the tweezer point just under the hump and lift it slightly. Do all 4.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Be sure to first disconnect the charger and the battery!
von
Antwort hinzufügen
Albert Einstein wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 882
