Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
175 Fragen Alle anzeigen
MacBook Air A2179 spill with beer and CPU getting hotter and shutdown
MacBook Air was spill with beer and i was open and disassemble and clean with alcohol then put it back and power on feel the CPU getting hotter and hotter until its power of so i let it cool and power on and it does the same and I dissemble that I found under the the other ide of motherboard where found some has been burns. Please i need those component if replace it can fix and i need help here ..thanks
Update (10/06/2021)
i check that 72-73 degree Celsius fan start on at 2664rpm and increase to 77 degree Celsius at 2688rpm and go over 90 degree Celsius until its shutdown
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Ouch! Not good
Your logic board needs some serious TLC!
The problem is none of the independent shops have access to the schematics or boardview drawings as they haven’t fallen off the back of a truck yet ;-}
So while an independent repair shop that specializes in Mac logic board repairs could likely repair yours at this point thats not possible. The next issue is you can’t swap out the logic board as the TouchID sensor is marred to the board so you will need a new board with its mated TouchID. Sadly, I haven’t seen any available yet.
See if Louis Rossmann can help you Rossmann Repair Group in NY
Otherwise its now a waiting game! for the schematics or boardview drawings or here’s a source I often use for parts: 13” MacBook Air 2020 M1 Logic Boards
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Chris Foliaki wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 101
