Zum Hauptinhalt wechseln
Am 20. September 2019 hat Apple das neueste iPhone angekündigt. Der Nachfolger des iPhone XR hat ein 6,1 Zoll LCD-Touchscreen, ein neues Zwei-Kamera-System und ist in sechs verschiedenen Farben erhältlich.
475 Fragen Alle anzeigen
Replaced Screen. iPhone 11 won't boot only shows flashing apple logo.
So i fitted a brand new replacement screen to an iphone 11. However, This time the phone is now showing a flashing apple logo really quick then stops for 10 seconds and shows it again. I can access the restore function however, phone is also unable to restore… I did a full restore before changing the screen and all was working fine. Apart from the obvious damaged screen. I’m kinda thinking the screen is defective but it shows the restore information fine so I know the screen is working… Is there anything i can do or should i just request a replacement screen. I am using a high quality display from iTruColor and it should be working normally.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
does the phone hold battery also this could be caused by the screen not being on right also did you disconnect the battery before putting on the new screen
von
@keith_themuscovyduck No I only disconnected the screen and it had about 40 percent in it when I powered off for the repair...
von
@keith_themuscovyduck also what do you mean by the screen not being on right? do i have to properly put the seal in and secure down before trying to boot?
von
My battery connector is connected and I'm still having this issue, any recommendations?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Battery Cable was disconnected. I was stressed out and didn't remember
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
See if it will boot with the top flex disconnected. It might have got damaged in the transfer process.
Bewertung 2
Antwort hinzufügen
Digitalclock wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 345
