Zum Hauptinhalt wechseln
Modell A1019 / 10 oder 20 GB Festplatte / Firewire Anschluss
iPod 2nd generation Headphone jack broken
Hi - my headphone jack is broken. I took the iPod apart and the headphone jack is soldered to board. Any idea how to replace it? I found a replacement part online but dont know how to use it. My model number is M8740LL/A. Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I have the same problem, please pass on the details of the replacement headphone jack so I can order one myself- thanks!
von
Can you please post what the replacement part is? I've looked everywhere!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You can try and solder it yourself after you practice on some other components until you become proficient, or you could just take it to your local TV/Radio repair person and have them solder it. Remember that what makes these guys usually expensive is to dismantle and diagnose, which is time consuming. In your case, it's disassembled and should be straight forward. Also, do not forget your local High School and Colleges, check for their electronics courses, if you do not a TV repair person handy. They are almost as hard to find as parts for your iPod. ;-) Elektronik-Übungsbausatz MK112 and http://www.aaroncake.net/electronics/sol... might be a good start....good luck
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
nbhidemisc wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 738
