Zum Hauptinhalt wechseln
Die 6. Generation des Surface Pro, erschienen im Oktober 2018. Erhältlich in Schwarz und Platin. Modell Nummer: 1796.
20 Fragen Alle anzeigen
Bright spots on display after 2 years?
When I view a dark picture on my Surface Pro 6 there show up some birght spots at the bottom of display (see picture). What could have happened and how could I fix it?
Thank you in advance. :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
While normally I would say that those three spots, or “smudges”, on the bottom of the screen appear to look exactly like some I have seen before caused by wear and/or excessive pressure against a specific spot, it looks like multiple others have reported spots in approximately that area on the Surface Pro 5th, 6th, and 7th gen: A light shadow on bottom of screen during system boot, is it normal?
This makes leads me to potentially the same conclusion as they came to - that it may be a known, but not owned by Microsoft, issue caused by design which puts too much pressure over time on that area of the LCD, causing those pressure points/damage to show.
I would appreciate a second opinion from another though.
Best of luck.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you very much, this was very helpful! It really looks like that design issue...
von
Apologies for the delay and I’m sorry that’s the case, but at least you know what it is now. I’m glad its at least still functional, if annoying.
Have a good rest of the week.
von
I have a surface pro 5 and it has spots identical to this one in the exact same place and almost the exact same shape
von
Antwort hinzufügen
Karale wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 39
Insgesamt: 2,802
