After Screen replacement shuts off when lid is closed
After replacing the screen on my 2017 MacBook Pro it only lets me turn the computer on by resetting it’s SMC. Also when ever I close the lid it turns the computer off and won’t let me turn it back on until I reset the SMC. Occasionally when I open the lid everything is on except the screen and it only works if I reset the SMC. I have ran diagnostics and said everything is good. I tried to reset the PRAM and still have this issue. I also tried booting into Saftey mode and tried closing the lid and no luck. Lastly I tried internet recovery and check the first aid on the drive and everything was good. Any ideas of what I could do or what the issue could be?
Ist dies eine gute Frage?
2 Kommentare
Why did you need to replace the display? That might offer us a clue on where to look.
Did you try running the onboard diagnostics? Restart your system and press the D key. Let us know what you get for an error.
Reference:
∙ Mac startup key combinations
∙ Use Apple Diagnostics to test your Mac
von Dan
I replaced the display because a friend tripped over the cord when charging and broke the original display. I did run that and it said everything was good no issues.
von Tyler Haehn
