Zum Hauptinhalt wechseln
How to fix cracked screen on 65 in phillips tv
Drop and cracked 65in phillips TV still worked. Came home two weeks later sound no picture
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Carla Shuman sorry to be the bearer of bad news. You cannot fix a cracked screen. The only thing you can do is replace the panel. Panels that size, if they are even available, cost more than a new TV, What I suggest is that you try to purchase a TV that is broken other than the screen and harvest the screen from that. OR you can try and remove the back cover from your TV and use the panel model number that is on a sticker on the back of that panel and try to find a good used one. The only other thing to do is to remove the boards from your TV and sell those separately. Then take the rest of the TV for recycling and invest in a new TV. Nothing here is good news but that is really the only thing you can do.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Carla Shuman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 17
Letzten 30 Tage: 144
Insgesamt: 2,150
