Zum Hauptinhalt wechseln
Repair and disassembly information for the first-generation Apple Watch SE, announced September 18th, 2020.
Can you name this part..!
I was fixing my I watch had a dead battery and I accidentally ripped the side of this cable shown in the image looks like a ground.. after looking on Google and asking what the cable was or even know what it is? anyone on here help as I need it thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@steveboy86 that is your display cable. Also referred to as the LCD Touch Screen Flex. Check places like this as well as other possible sellers
War diese Antwort hilfreich?
Bewertung 0
System in Package (SIP) module with its ribbon cable unit which connects to the display assembly. Apple doesn’t offer the cables as a serviceable spare to their repair depots. The full SIP will need to be swapped out. If you can find a watch for parts you might be able transfer the cable unit but its not easy!
If you damaged the shielding part you might be OK. I use some conductive copper foil which I insulate on top to connect the two parts together after exposing some of the copper for the foil to connect to 3M RF EMI Copper Foil Shielding
Bewertung 0
Antwort hinzufügen
Ste wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 640
