Zum Hauptinhalt wechseln
Der Ford Explorer und der Mercury Mountaineer wurden beide für das Modelljahr 2006 auf einem neuen Rahmen aktualisiert, der von Magna International anstelle von Tower Automotive produziert wurde.
AC only blowing heat
My blend door actuator started clicking and was stuck on AC. I finally just replaced the actuator and now I have heat but I now only have heat. No matter what I set the temp setting to it just blows hot air out of all the vents on both sides, driver and passenger.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
i have ford explorer model 2010. same issue of no cold air blowing
checked and found compressor clutch relay not energizing. while jumping he clutch relay contact ,compressor clutch engaging. seems some control logic blocking the signal to compressor clutch relay. anyone can suggest what are the signals blocking the compressor clutch from engaging?
von Teilen
Einen Kommentar hinzufügen
1 Antwort
I would guess that there is still a problem with the blend door.
If it were “clicking” I would think the actuator was attempting to move the door, but something was wrong with the drive.
Or it could be that the actuator did not get installed properly.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
My only guess is there is something wrong with the new actuator. My setting was already set on cold so it started blowing hot before I messed with it. I’m not sure how it could be installed incorrectly. There is only one plug and the shaft only fits in one way.
von Teilen
Did you fixed the issue? Because I’m having the problem too
von Teilen
Antwort hinzufügen
Scot Williams wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,317
