Zum Hauptinhalt wechseln
A1418 | EMC 2889 | Ende 2015 | 1,6 GHz Dual-Core Intel Core i5 oder 2,8 GHz Quad-Core Intel Core i5. Erscheinungsdatum 13. Oktober 2015.
What does blinking LEDs 1 and 2 mean?
iMac 21.5” does not power up, no chime is heard. I know that LED codes are: LED 1 on= trickle voltage from power supply is detected by logicboard. LED2 on= logic board has detected proper power from the power supply when the computer is turned on.
The problem is BOTH LEDs 1 and 2 are BLINKING (not ON continuously) when I connect the AC power cable to the mains wall socket. What problem does this point to?
Ist dies eine gute Frage?
Bewertung 2
4 Kommentare:
Can you offer some additional details on what preceded things here.
von
Nothing unusual happened prior to. Thing just suddenly won't turn on.
von
Where is the light coming from?
von
Light comes from the vertically arranged LED array on the logicboard.
von
Einen Kommentar hinzufügen
1 Antwort
What does the other LED’s telling you?
Did you try reseating the RAM? Did you replace the RAM you might have a bad SO-DIMM.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
The RAM is permanently soldered to the logicboard in this model, and cannot be replaced.
von
Dan, when I press the power button, the 2 other LEDs remain unlit, #1 and #2 LEDs turn off. When I release the power button, LEDs #3 and 4 remain off and #1 and #2 start to blink again.
von
@Bernie - Sorry your right! One of the few iMacs with soldered RAM.
I think your logic board is blown then.
von
Antwort hinzufügen
Bernie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 242
