Hi,
Here’s the hardware maintenance manual for the laptop.
Go to p.78 to view the necessary pre-requisite steps and then the procedure to remove NFC module and cable.
Go to p.85 to view the necessary pre-requisite steps and then the procedure to remove the fingerprint reader and fingerprint reader cable.
Go to p.88 to view the necessary pre-requisite steps and then the procedure to remove smart card reader or dummy smart card reader and smart reader cable.
Go to p.100 to view the necessary pre-requisite steps and then the procedure to remove the antenna kit.
This will show you how to install all the features by reversing the removal procedures for each one.
Here’s the parts list for the 20LB model laptop. Click on Select Commodity to find the part categories and then select the ones you want e.g. Cards Misc Internal (6), to get the part numbers for the components. Search online using the part number only, appropriate to what you want, to get results for suppliers.
Here’s the parts list for the 20LC model laptop, just in case there is a difference between the two model variants. I didn’t check whether there is or not.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
