Zum Hauptinhalt wechseln
Reparaturinformationen für den iPod Nano der 6. Generation, erschienen im September 2010. Modellbezeichnung: A1366.
Why does my iPod nano lose battery so quick?
I charge my nano until it's fully charged but it runs out of battery about 2 hours later.
Ist dies eine gute Frage?
Bewertung 5
4 Kommentare
My 4 gen ipod mini dies so fast when it's fully charge as I remove of the charger to go low battery what should I do?
von
I got a 6th gen nano and when its fully charged I will unplug it, but it literally dies in 5 seconds.
von
I have this problem as well ... it's a new Ipod Nano, I charge it fully, I play it, and it dies in less than 2 hours.
von
you need to replace your battery. it does require soldering.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It does sound like your battery is ready to be replaced. Follow this guide to show you how to get to the battery. It is a bit of a PITA due to the size of the Nano. Of course, before you take it apart, you could also give this a try. the battery is available at places like this. I hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
thanks 4 the info but the thing is i just got it about a week ago. Could it b something else?
von
Not really, you could check on your settings and make sure that your EQ is off etc. You might also try another charger, anything is possible. If you just recently got it, any chance you got some sort of warranty?
von
thanks sooo much
von
Maybe Its cause since it is so tiny that the battery should be tiny to so that means a little bit of battery
Bewertung 0
Antwort hinzufügen
Vicki wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 8,550
