Zum Hauptinhalt wechseln
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by a system integrator using off-the-shelf parts.
Can power supply fuse (F12.5A) be replaced wih a 12A fuse?
The F12.5A ceramic fuse for 700 watt ATX power supply is blown, I think it may have been because of an accidental short. I have searched widely and although different sites list the fuse, no one has one and seem to indicate that the fuse is no longer produced. Would a 12A fuse work or is that half amp a deal killer? The load would be MB, 3 HD, 1 optical drive. Video would not be a gaming one.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yess O.5 amp lower is acceptable, make sure to test fuse by checking its continuity through a tester meter always before installing it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
hadn't thought about testing the fuse - useful!
von
Hilfreichste Antwort
Lower is fine but NOT higher.
Bewertung 2
Antwort hinzufügen
Jim Lindemann wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 41
Insgesamt: 571
