Zum Hauptinhalt wechseln
A2115 / 2020 / Prozessoren beginnend mit 3,1 GHz 6-Core i5, bis 3,8 GHz 8-Core i7. Markteintritt am 4. August 2020.
Can I Remove the Stand?
Can the stock stand be removed on the mid-2020 iMac as on the mid-2012 and later iMacs? When I ordered my 2020, I didn’t realize the VESA mount was an option. The stock stand is not ergonomic for me.
Honestly, I’d rather deal with what I have than leave the stock stand on with one of those VIVO mounts. I may change my mind later…
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you just bought it from Apple return it ASAP! And order the VESA mount version if it’s that important.
Sadly you need to fully disassemble the system to get to the screws which holds the foot inside.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thanks. It’s not what I wanted to hear but at least I know.
von
So that means, when fully disassembling the iMac, you can in fact change to VESA? Because i can't find another way
von
@Robert - I’m not sure I follow you here… yes, you can switch the foot to VESA mount, but!! It requires a complete disassembly of the system to get to the mounting and you will also need to get the VESA mount hardware both internal and external.
von
Antwort hinzufügen
Joel Black wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 1,925
