Has anyone replaced the internal hard drive yet?
Has anyone found an M2 that fits inside the x series x (internal hard drive) and if so has anyone been able to format it to run the OS?
Ist dies eine gute Frage?
No need. Find a CFexpress to M.2 adaptor and plug the supported M.2 SSD in expansion slot in the back of the console.
In this way, you don't need to break the seal which may be considered warranty void in some countries.
War diese Antwort hilfreich?
Have you had any luck with this? I have read only bad reviews of it.
You can install a new SSD in the console and download the OS from this link.
To use the Offline System Update, you'll need:
Most USB flash drives come formatted as FAT32 and will have to be reformatted to NTFS. Note that formatting a USB flash drive for this procedure will erase all files on it. Back up or transfer any files on your flash drive before you format the drive. For information about how to format a USB flash drive to NTFS using a PC, see:
How to format a USB flash drive or external storage device to NTFS on Windows
To perform the update:
unless something has changed recently......... this will not work as the original internal SSD is married to the motherboard and the keys are in a hidden partition.
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 1,049
