Zum Hauptinhalt wechseln
Der 2017 erschienene Staubsauger Dyson V7 bietet bis zu 30 Minuten lang konstante Saugkraft ohne Saugkraftverlust. Mit nur einem Klick lässt er sich in einen Handstaubsauger verwandeln. Das hygienische Entleerungssystem befördert den Schmutz in einem Handgriff nach außen.
What does LED color mean on the Dyson V7 REPLACEMENT battery?
I just bought a Dyson V7 battery from ifixit.  The LED color is different from the original battery.  What do the different LED colors/blink patterns mean on the replacement battery?  E.g., what color means it's charging & what color means it's finished charging & what color means the battery is low & needs charging.  Thank you.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hello Vicki
When charging the battery:
  1. A solid blue light indicates that the battery is charging.
  2. No light indicates the battery is fully charged.
  3. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold).
  4. A flashing red light indicates that there is a fault, please call the Dyson Helpline.
Hope that helps.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I just installed my iFixit V7 replacement battery and it gives me a solid GREEN light. So the above list applies to the factory Dyson battery but not necessarily to iFixit's replacement battery.
von Teilen
Exactly my question too!
von Teilen
What does a solid Green light mean when plugged in? I bought the Dyson V6 battery from iFixit and I’m getting a solid green light when plugged in for the very first time.
Bewertung 0
3 Kommentare:
This was a question
von Teilen
I have the same issue -- a solid green light.
von Teilen
if i was a betting man, which I am, i would/will put all my money on the green light is ifixits aftermarket blue light.
von Teilen
Antwort hinzufügen
Vicki Pelton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 26
Letzte 30 Tage: 87
Insgesamt: 19,754
