Zum Hauptinhalt wechseln
Informationen, wie du die Fläche um dein Haus herum in Schuss hälst
Engine shuts off when making a left or right turn
So I have a areator with a Honda GX120 for the motor. The engine will idle and run, I can go in a straight line but when I have to turn either direction it shuts off. It looses all spark I don't know what could cause the issue
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@travis78 check all the wiring. Make sure that they are all properly connected. Also check for any wiring that may be rubbing against the frame of this as well as the stop/kill switch. It definitely sounds like something is shortening out.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Travis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 70
