Need help troubleshooting a battery repair.
I recently did a battery replacement on a Surface Pro 4. The repair itself went off without a hitch, but after I made sure everything powered on and put the screen back on I noticed an issue. When not connected to a charger, the laptop will boot, be fine if it’s not moved, but as soon as it’s bumped, even from an aggressive key press, it will lose power. I think that maybe the battery contacts on the PCB might need to be cleaned, but I would like to hear everyone else’s opinions in case that isn’t the issue. Thanks!
Ist dies eine gute Frage?
Phoenix Knipe it is possible. Just make sure that all the flex cables are properly attached and seated correctly. What a Royal PITA that battery is :-)
von oldturkey03
