Zum Hauptinhalt wechseln
Apples Mainstream-iPhone 2021 wurde am 24. September vorgestellt und kommt mit einem 6,1-Zoll-OLED-Display, einem dualen 12-MP-Kamerasystem und in fünf verfügbaren Farben. Nachfolger des iPhone 12.
94 Fragen Alle anzeigen
Will iPhone 13 still function if all cameras are removed?
My employment requires personal phones to have its cameras destroyed or completely removed for security purposes. Will an iPhone 13 continue to function normally (with Face ID off) even if all cameras are removed?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I suspect so. I can’t confirm this for sure, but on other models leaving the camera disconnected does not impede its ability to boot and function normally, as far as I know.
The only thing i will mention is that the front facing camera is part of the whole Face ID module, and although it’s likely possible to extract just the camera out of that, I would recommend leaving it all together if you’re going to pull it out, so if it ever needs to be reinstalled it can be done as easily as possible. I don’t believe there are any sensors in either of these parts which may trigger bootloops since iPhones typically expect check ins from these sensors every so often.
It’s sort of an intrusive process, but I wouldn’t expect it to cause any functional issues outside of the expected loss of camera and Face ID.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Chad T wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 94
