Zum Hauptinhalt wechseln
Beats x: Is upgrading to a 300mAh higher capacity battery a good idea?
My Beats x are a few years old now and the battery no longer lasts more than an hour so I was looking to replace it with a new one. I spotted a seller online advertising a 300mAh battery. I believe the original is ~50mAh. It’s only a few bucks more to buy but I don’t see any reviews online of anyone doing it so I’m concerned that there might be a reason I shouldn’t.
Does anyone have any thoughts on if it’s worth doing?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi
In the past I have replaced iPod battery’s with higher mAh battery’s and it went quite well however I’d left very little space inside of the iPod so I’m not too sure the battery would fit nicely inside of the beats X as they have such Little room even with the original battery and even if it did fit I can’t imagine it would be very safe because when the Samsung galaxy note 7batterys were exploding it was due to having almost no space so if I were you I would see if anyone else has done it but if you are the first person to do it I probably wouldn’t due to the potential safety concerns
I hope this answers your question
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Dagger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 352
