Can I replace battery with Higher mAh capacity?
Both batteries are 18650. Using same BMS. But one has higher mAh rating. Is it possible to replace current one with higher mAh ?
My worry is how speaker tracks battery capacity and charges battery. Say original battery capacity is 2200 mAh, is replaced with 3500 mAh with same BMS and everything. Will it charge battery to full capacity of 3500 mAh? or charge level will be limited to 2200 mAh.
Also, would using higher C rated battery damage speaker or components ?
Thanks.
Ist dies eine gute Frage?
