Zum Hauptinhalt wechseln
7.2 megapixels, 3x optical zoom, 2.5 inch LCD screen, released in August 2006
5 Fragen Alle anzeigen
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare
what error no. does it give?
von
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
von
Any way to fix it?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Danny Arenales wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 13,261
