Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
Password digits 3,6,9,cancel not functioning
I replaced the digitizer about 18 months ago. It has been flaky ever since. I reopened it to see if I could fix this problem. Now the symptom is the digits 3,6,9,and cancel will not respond when opening password. This symptom is not now flakey but solidly not functioning. I thoroughly cleaned the connectors per your instructions. My question is, is it the digitizer or the processor. Any ideas?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hey Chuck,
Seems to me like a logic board issue as concurred by @beanman56 . With that being said maybe there are dead spots on the screen which are causing this.
Did this happen after an update or did something happen to the device prior?
IMPORTANT NOTICE:
From Sunday Aus to Friday AUS, i will be unavailable as i am camping then.
War diese Antwort hilfreich?
Bewertung 2
Its the digitizer
i’m 99.5% sure
Bewertung 1
2 Kommentare:
Replaced digitizer same problem.
von
Sounds like its a logic board problem then :/
Like the software or something
von
Antwort hinzufügen
Chuck Porembski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 18
Insgesamt: 260
