Zum Hauptinhalt wechseln
Repair guides for the business model of the seventh generation of Microsoft's Surface Pro. The Surface Pro 7+ was debuted for consumers on September 22, 2021.
Surface type cover not powering on and connecting to the computer
So…I currently use a surface pro 7+ for everyday and all of a sudden my keyboard stopped working (For context here’s a few things that are normal):
  • Surface turns on
  • Surface reaches login screen
  • Surface logs in and is on home screen
  • Surface is in UEFI bios
  • Surface is in Advanced startup options.
In none of these scenarios does the keyboard work. No lights are on. No signs of life. However after a reset of windows it does work but then small things do trigger it to stop working again.
I have tried literally everything from cleaning the contacts to even (repeatedly) turn on and off the type cover port in the UEFI bios with absolutely 0 luck at all.
Pls help as this is a machine used on an everyday basis.
Thanks.
Update (10/04/23)
So, after going back and forth with Microsoft, the only solution they had was to send me a new keyboard, which now works fine.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Plugin the external keyboard to check whether the fault is in the keyboard or something else. As you said after windows reset it works, which means there might be some software glitch. Try to update or restore the updated driver for the keyboard. Sometimes keyboard gets turned off from bios too. You should also check from there.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Unfortunately I did try all of those and none of it worked. It happens at random and the only real way to fix it is to reset the whole device
von
@np_f1_2021 It might possible there is some virus that stops or turn it off. It happened to me a long time before. After reset doesn't open any drive. First Install and scan the whole PC with a good Antivirus.
von
Funny thing is it happens when the following occurs (so far):
A monitor is connected (my personal one is a Dell S2722QC type c monitor)
My specific wireless keyboard (Mx keys mini for Mac because I also use a Mac and bought the keyboard without windows pc in mind lol) is connected
And probably more to come
von
And then it never returns until the pc is reset
von
La mia tastiera funziona su altri ma sul mio Surface pro non funziona più
Bewertung 0
1 Kommentar:
Il bios UEFI blocca la type cover port
von
Antwort hinzufügen
Nick P wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 57
Insgesamt: 3,635
