Zum Hauptinhalt wechseln
Eine von Sony Computer Entertainment produzierte Fernsehspielkonsole; die PlayStation 4 Slim (CUH-2000-Serie) ist ein dünneres Ersatzmodell für die originale PS4. Angekündigt am 7. September 2016.
20 Fragen Alle anzeigen
Where can I get this missing piece?
A long time ago my disk drive didn’t work and I took it apart apparently the loose piece fell out and I lost it. Recently I opened it up and found out what I needed. Other people have lost this white plastic piece and it was called F-105. Other people have said I need to buy a broken console and get the piece from there, but I don’t want to spend $40+ to get one. Does anyone know how to get it?
Picture shows where the piece used to be.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I’ve spent over an hour now searching. Even the places that have “roller kits” don’t include the connecting rod bit. I can’t fathom replacing an entire disc drive ($40+ as you discovered), let alone an entire console ($100+), just because of a stupid little plastic dowel. If it were me….I’d make a substitute connecting rod, really what is there to lose. Either hand carve it or if you know someone with a 3d printer, design and print some. Good luck!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Sorry it has been a long time. I appreciate your answer and will try to locate a replacement or try to make it.
von
Antwort hinzufügen
Brayden S wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 139
